Diy - 2005 Es330 - 60k Service Check List
hadi
Hello everyone,
I have 2005 ES330 is reaching 60K for service. I have done the following but interested to see anyone has any additional list that I need;
Replace Oil and Filter
Replace Air Filter
Replace Cabin Filter
Rotate tires and balance.
Check and Replace Brake Pads
Check Transmission Fluid level and color - still looks good replaced 30K but do I need to get another service, please comments.
Does anyone know where is the fuel filter and PVC valve, do they required replacement?
Dealer said, I don't need to replace the spark plugs until 120K, what do you think?
  • 2 years later...
ttt
Thanks,
Bill
Hello everyone,
Replace Air Filter
fuel filter is in the gas tank, should be good for life of fuel pump.....PCV valve should be on the rear valve cover. Spark plugs are indeed good for 120k miles if not longer. As for transmission, check color and level and should be good, I personally replace mine every 30k miles....
Many thanks!
Bill
