Trunk Won't Stay Up
Jacksteak
Need help with determining the problem witht hte trunk. It appears like these little shock like tubes are not working.
The rear hatch struts usually have a longer life than 6 years - mine (on the '99 RX) lasted nine years. You can get them on-line:
(see: http://us.lexusownersclub.com/forums/index...=0#entry330684) the forum member blk_on_blk found the best place to buy them and also had a very clear 'how-to' guide gor the RX300.
Good luck!
The lift cylinders wen bad on my 4SC430 after 5 years and low usage. The dealer wanted ~$400 to replace them. I bought OEM replacements from Sewell Lexus in Dallas online at http://www.sewellpartsonline.com/parts_det...44317&all=Y They cost $200 and took 2 minutes to replace. Just pop the ring clip holding the old one on and push the new one onto the stud.
Got mine on ebay too...Cost me $55. Put them on in less than 2 Minutes Flat! Trunk Opens perfectly now. I used to have my California Dust Wand holding it up no more !!!!!!!
2002 SC - 430
  • 1 year later...
