Cross-drilled/slotted Rotors And Pads
Hey Guys and Ladies, I'm looking to upgrade the brakes on my 99 GS400. I'm looking to get the Cross-drilled and slotted rotors with a good set of pads for the front and rear. Any recommendations on which ones to get and where to get them would be much appreciated.
I have a few people talking about the Brembo cross-drilled/slotted with the EBC green stuff pads?
Please share your expertise, Thanks
That's what I had with some SS brakelines.. You'll definitely feel the difference from stock.. Question for you, why don't you spend a couple hundred more for some TT brakes? They have great breaking power and are very affordable.. The only problem is I think you may need spacers if you don't have at least Medium disk front rims..
  • 8 years later...
I know this is an old topic however, did lexappeal get yours done? If so, has anyone else had any issues after putting on these cross-drilled/slotted rotors and pads??
I've had to change two sets on each then, I had to move back to the manufactered rotors & pads.
Before I spent the large amount on the whole SS brake system, I wanted to make sure everyone continued to have the same problems I had.
Thanks.
