Mike Floutier Posted August 27, 2009 Share Posted August 27, 2009 Hi, I've just noticed that one of my xenon headlamp bulbs goes off after about 2 minutes driving. If I switch the headlights off and on again it lights up again but goes off again after 2 minutes, and so on. Any idea what's happening and how to fix it? Thanks. Mike Quote Link to comment Share on other sites More sharing options...
JimsGX Posted August 28, 2009 Share Posted August 28, 2009 I would suspect that you have a bad ballast. Quote Link to comment Share on other sites More sharing options...
Mike Floutier Posted August 28, 2009 Author Share Posted August 28, 2009 Thanks Jim, I have heard of "Ballast" but can see no mention of it in the manual. Where is it located? Thanks Mike Quote Link to comment Share on other sites More sharing options...
JimsGX Posted August 28, 2009 Share Posted August 28, 2009 On your year vehicle I'm not sure. I know the general concept of how all HID's systems work and have experienced this problem with other aftermarket HID's. There aren't too many components to consider. Two ballasts, one or two relays, the bulbs and the wiring harness. In my experience, a ballast malfunction is what made the light go out. Jim Quote Link to comment Share on other sites More sharing options...
Mike Floutier Posted August 28, 2009 Author Share Posted August 28, 2009 Hi Jim, Looking at http://www.toyodiy.com/parts/p_E_2002_LEXU...EAGKW_8101.html it seems that in addition to the bulb there is thing called a "light control computer" (this ties up with the manual). I presume this includes all the gubbins - ie. ballast, relays etc - as it costs over 500 euros. I think what I'll do first of all is switch the bulbs around to see if the problem moves over. If it does then it must be the bulb and I can just change it. If the problem remains on spite of switching then it is probably the light control computer. Hopefully it's the bulb - it has done 186,000 miles and I always drive with the lights on so it may well just be the bulb. Will post how I get on. Thanks again. Mike Quote Link to comment Share on other sites More sharing options...
HankJ Posted August 28, 2009 Share Posted August 28, 2009 When this occured to my 2004 430LS, it was the bulb. I was happy that the computer wasn't the problem. you can get a new bulb, or swap bulbs from side to side and se if the problem tracks, that is what I did. bets of luck, Hank Quote Link to comment Share on other sites More sharing options...
curiousB Posted August 28, 2009 Share Posted August 28, 2009 Hi Jim,Looking at http://www.toyodiy.com/parts/p_E_2002_LEXU...EAGKW_8101.html it seems that in addition to the bulb there is thing called a "light control computer" (this ties up with the manual). I presume this includes all the gubbins - ie. ballast, relays etc - as it costs over 500 euros. I think what I'll do first of all is switch the bulbs around to see if the problem moves over. If it does then it must be the bulb and I can just change it. If the problem remains on spite of switching then it is probably the light control computer. Hopefully it's the bulb - it has done 186,000 miles and I always drive with the lights on so it may well just be the bulb. Will post how I get on. Thanks again. Mike I'd try this first. Don't leave any oils from your finger on the bulb. If so wash fully with alcohol and clean cotton cloth. I suspect the bulb is near end of life and the ballast has an over-current and/or over-heat circuit to stop a runaway current situation. I suspect its doing exactly what is is supposed to do. Quote Link to comment Share on other sites More sharing options...
synikal1022 Posted August 28, 2009 Share Posted August 28, 2009 The same thing happened to my LS; at first the buld started flickering at start up then lit up normally then it would light for a couple of minutes then went dark...........I replaced the buld, end of story. I was glad it wasnt anything serious. Quote Link to comment Share on other sites More sharing options...
Slvr99LS Posted August 29, 2009 Share Posted August 29, 2009 Mike, in the event it turns out that it is the ballast at fault rather than the bulb, on the 1998 - 2000 models with HID option the ballast is located directly underneath the entire headlamp assembly and is attached to the bottom. In order to gain access to it the whole lamp assembly has to be unbolted from the car, which doesn't look all that difficult. Due to the completely ridiculous OEM replacement costs, as an insulator against future 'wallet-shock' (and having never owned a vehicle previously with HID lamps), I bought a complete spare assembly with some cosmetic flaws on eBay not too long ago in case of an occurence just like you're currently experiencing. Curious how you make out with this particular issue since from what I've gathered it apparently isn't all that common for them to fail - please keep us posted. Quote Link to comment Share on other sites More sharing options...
Mike Floutier Posted August 29, 2009 Author Share Posted August 29, 2009 Thanks everyone, I think I'll just order a new bulb cos it's so old. Will let you know how it goes. THanks again Mike Quote Link to comment Share on other sites More sharing options...
