cduluk Posted July 20, 2009 Posted July 20, 2009 Hey guys/gals, I'm having the whole left side of my Rx400h re-painted due to some vandalism. The body shop is also painting the inside door jambs so i don't have to see the masking "line" all along the edges of the body where they meet the doors. They told me i have two options concerning the info labels on the door jambs. They can either mask them off and paint around them (which will look tacky) or they can remove the labels altogether. But they said if they remove the labels, they will be rendered useless and won't be able to be put back on after paint. I asked if they could order new labels, but the shop stated they were not able to be purchased, and that it was actually illegal to put labels on over paintwork, since the absence of labels indirectly shows presence of paintwork when buying or selling... I understand that the "VIN" labels on the jambs shouldn't be put back on over paintwork, but the three info labels on the drivers door jamb shows the production date, paint codes, tire pressure info etc, info that to me seems important to e able to refer to. Here's a pic i found of another Rx's door jamb labels: So is the shop right? I looked in the Rx400h parts manual, and there's a page dedicated to "labels", but i can't find any that look like the ones on the drivers door jamb. The top black one is the one that's pretty much custom for ever vehicle since it contains the vin and production date which vary between cars. The other two are the same for all of them. Anyone have any input on this? thanks!! :)
nc211 Posted July 20, 2009 Posted July 20, 2009 I would have them tape them off and keep them, for sure. Otherwise, when it comes time to trade/sell the car, it will be more difficult to explain why they're not there "I'd notice this right away", than why there appears to be a tape line. With the tape line, you can simply tell them the truth without having to worry what they're thinking (if they notice at all and ask the question). But if you remove the labels, then you can bet they'll notice, and you can bet they'll probably wonder if you're telling them the whole story, or if something else happened that destroyed them. When I bought my first Lexus, I was told by a couple of Lexus owners to make sure to check all the doors for their tags, to make sure nothing had happened to them, as it's a tell-tale way to check. Keep the labels!
cduluk Posted July 20, 2009 Author Posted July 20, 2009 If they can't save the labels or if they can't find replacements, i'll scan someone else's, edit them with my info, and have a sticker company make me some duplicates :D I plan on having the car for a long, loooonnngggg time, so my biggest worry isn't resale value if they're missing, but rather looks.
Lexusfreak Posted July 21, 2009 Posted July 21, 2009 I'd just mask them off too......spend a few extra minutes to get it 'perfect' & Bob's your uncle. ;)
cduluk Posted July 21, 2009 Author Posted July 21, 2009 They attempted the "masking" of the stickers on my rx300 when they did the pass. side after i clipped a fire hydrant, and it was obvious something was wrong. The paint was as high as the thickness of the sticker. If you ran your finger across the sticker, you would feel that the sticker was at the same level as the paint. It looked like they sprayed the door jamb with clear, then placed the sticker in the clear before it dried... It looked, odd...
TA in KC Posted July 21, 2009 Posted July 21, 2009 Yes, the stickers/labels can all be replaced but they must be ordered and installed through a Lexus dealership. The old sticker also must accompany the request for a replacement. It works the same way as replacement VIN plaques. You should be able to find the forms to request a replacement sticker on the Ebsco auto repair reference center. I would suggest giving them to the body shop and have them work everything out with a local Lexus dealership.
cduluk Posted July 21, 2009 Author Posted July 21, 2009 Yes, the stickers/labels can all be replaced but they must be ordered and installed through a Lexus dealership. The old sticker also must accompany the request for a replacement. It works the same way as replacement VIN plaques.You should be able to find the forms to request a replacement sticker on the Ebsco auto repair reference center. I would suggest giving them to the body shop and have them work everything out with a local Lexus dealership. Hey, thanks! I google'd "Ebsco auto repair reference center" but didn't find anything?? I looked on the lexus parts manual page online, and think i've identified two out of the three stickers. Can't find the black one though.
denslexusgx470 Posted July 21, 2009 Posted July 21, 2009 The black one is SPECIFIC for that vehicle, and that vehicle only. It has the production date, VIN, and where the car was manufactured.
cduluk Posted July 21, 2009 Author Posted July 21, 2009 yeah that's the only one i'll have trouble getting. I contacted Lexus parts (why didn't i think of this before??) and they said the bottom two they could get in about a day, but the black one would take 6-10 weeks to deliver. I'd need the old one to present (to get info from) and they'd need to make another... I'll have to see if the shop kept the sticker or not...
SW03ES Posted July 30, 2009 Posted July 30, 2009 I don't understand why they are painting the inside of the B pillar when the damage is limited to the exterior of the door skins...
cduluk Posted July 30, 2009 Author Posted July 30, 2009 I don't understand why they are painting the inside of the B pillar when the damage is limited to the exterior of the door skins... Only to avoid the mask line around the edge of the doors (on the body). I went to the shop today to drop off the wheels i want them to put on, and i saw the progress. They have the hood removed (being sanded down) and have the FL fender sanded down to metal along with both side doors and part of the LR 1/4 panel. They told me they're going to try to 'mist' the edges and wetsand and polish to avoid having to paint the door jams or have a sharp mask line... I don't know, they know what they're doing i guess. Should be done next monday or tuesday...
SW03ES Posted July 31, 2009 Posted July 31, 2009 Are they painting the roof and the support beam above the doors?
cduluk Posted July 31, 2009 Author Posted July 31, 2009 They're not painting the roof, but they are clearing/ painting the 3" or so section of metal that starts at the windshield that merges into the rear 1/4. This is what they told me they were doing: But when clearing the top section, they'd need to mask off the door jams, which would leave a mask line that would be visible along the rim when the doors wher open. The line would look like this: So what they're going to to is to try to 'mist' along the rim, wetsand and polish it so you won't be able to see the "line" between the door jams and where was clearcoat, sort of like a blend.
cduluk Posted August 2, 2009 Author Posted August 2, 2009 i guess, the shop will work their magic! :)
cduluk Posted August 4, 2009 Author Posted August 4, 2009 I hope it turns out well, I'm sure it will. Ugh me too, they've certainly had it long enough. They told me it would be done Monday or Tuesday of this week, so that means today? Given my experience with them, they're pretty bad on deadlines. Ordinarily i would freak, but i know when i'm building/working on something, whenever i'm nagged i rush and the work comes out crappy. So i'd rather let them take their time...
SW03ES Posted August 4, 2009 Posted August 4, 2009 I'd let them take as long as it takes to make it perfect...I wouldn't hurry them. And don't pay for it or take delivery of it until its perfect, thats a BIG repair, a lot of paint work and it very well may have some rough or wavy points at first. If it does...tell them to keep it until its right. When I had my bumper repainted by my shop who does INCREDIBLE work...I sent it back twice before I accepted it. Most people would have just taken it the first time...but I'm not most people.
cduluk Posted August 5, 2009 Author Posted August 5, 2009 I'd let them take as long as it takes to make it perfect...I wouldn't hurry them.And don't pay for it or take delivery of it until its perfect, thats a BIG repair, a lot of paint work and it very well may have some rough or wavy points at first. If it does...tell them to keep it until its right. When I had my bumper repainted by my shop who does INCREDIBLE work...I sent it back twice before I accepted it. Most people would have just taken it the first time...but I'm not most people. Oh trust me, i won't accept it if i'm not perfectly satisfied. The first time i had them do work, i made them spend a few more hours with it wet sanding and polishing a few dust particels they missed. The fact that they've had it for one month, it'd better be perfect.
Duckman Posted August 5, 2009 Posted August 5, 2009 I have been following along, reading about your keying incident and the repair/painting you are going through. First of all, sorry about the keying...that sucks. I'm sure I would have gone through the moon if it were my car. Second, I can't wait to hear how your paint job looks! A month is a long time to wait, so I hope it looks like it just rolled out of the factory! --Duckman
cduluk Posted August 6, 2009 Author Posted August 6, 2009 I have been following along, reading about your keying incident and the repair/painting you are going through. First of all, sorry about the keying...that sucks. I'm sure I would have gone through the moon if it were my car. Second, I can't wait to hear how your paint job looks! A month is a long time to wait, so I hope it looks like it just rolled out of the factory!--Duckman hey thanks for the kind words- i called the shop again today, apparently its not done yet... maybe tomorrow? ugh...
cduluk Posted August 8, 2009 Author Posted August 8, 2009 Well i FINALLY got my car back from the body shop yesterday :) The paint job was absolutely PERFECT, and i literally mean PERFECT! I can't find one single imperfection, ANYWHERE. I can't even tell it was painted. The finish is spotless and smooth and shiny as ever. And best of all, NO LINES! They blended the clear so perfectly along the edges of the frame, the transition is seamless around the door jams. They said they "misted" the edges and wet-sanded and polished the door jams. This way i get to keep the stickers :) And they didn't do it the fast/cheap way either- they removed the door handles, all window trim along with the door bumper "strips" that are in the center of each door, painted those too then put them back on. The color is a perfect match to the rest of the car. I couldn't be happier! They also replaced the windshield with a factory Lexus one, and they put my chrome wheels on for me too. And on top of that, when i picked the car up, he gave me a personal check for $500. Maybe for being a repeat customer and for being so patient? :) They did get $6,000 from the insurance. $1800 of that just for the windshield... So here are some pics of the results :)
Duckman Posted August 8, 2009 Posted August 8, 2009 Very nice! LOVE the chrome wheels! It's great that you found someone that would pay attention to all of the details that were important to you. Even though you had to wait...I'm sure that the finished product more than makes up for the time. Congrats! --Duckman
