Rear Right Hub Removal
I looked at the parts list for SC.
Looks like ;disc off:
large nut on end of shaft off
hub end off.... and there is a snap ring behind the oil seal, is this holding it?
Just trying to help, never done this job!
I guess there is a snap ring or something because I got the rotor off, calipers, large hub nut and now there isnt anything I can see thats holding it on? I dont get it.. I might just take it to a shop
ummm... these cars use sealed bearings and the hubs are pressed on. you need to remove the entire hub assembly from the car and use a press to push out the inner hub from the bearing and push the bearing from the hub carrier. so basicly take the hub to a machine shop or somewhere that does press work and have them press the new bearing in
Thanks everyone, I am actually taking my car to a friends house who has a lift, pneumatic tools and a press. Now that GrnSc400 gave me the right info and exploded diagrams I think I should be able to do this. I'll post up the DIY pics after this sunday.
