04 RX330
After I drain and refill the transmission fluid, run the car 30 minutes, then check the fluid level. It is right between the cold line and hot line. I am not sure how much more I need to reach the hot line. Thanks for your reply!
04 RX330
RO- I see you have a 330. Don't know if that transmission is different than the earlier ones or not, but it probably wouldn't make much if any difference in what you asked about. The answer would be likely a pint but probably less than a quart.
