lfty5150 Posted June 5, 2009 Share Posted June 5, 2009 Fellow Lexus owners, I have a 2002 Lexus IS300 with a navigation system, when I start the car the nav systems says unable to read dvd, check to see if correct map? Is my DVD player bad, the disc is the original, i ejected the disc and its brand new. I called lexus and the player costs $1500. to replace. Any suggestions to repair this one. any help is greatly appreciated. Rob Quote Link to comment Share on other sites More sharing options...
qp76 Posted June 5, 2009 Share Posted June 5, 2009 Fellow Lexus owners,I have a 2002 Lexus IS300 with a navigation system, when I start the car the nav systems says unable to read dvd, check to see if correct map? Is my DVD player bad, the disc is the original, i ejected the disc and its brand new. I called lexus and the player costs $1500. to replace. Any suggestions to repair this one. any help is greatly appreciated. Rob try to insert/reject few time when the car is in power on position. 2nd, the disc must be GEN 2/3. if you have original disc and wrong GEN# the player will not work. last option is remove cable from battery for 5 min and reconnect it. the dvd will reload the gps base software from the disc and update the system (it may corrupted). Quote Link to comment Share on other sites More sharing options...
sakataj Posted June 6, 2009 Share Posted June 6, 2009 um, you do know u posting in the gs section dont you? here check this post out....bout my nav troubles. if u have a gen2/3 unit it might be the same fate for yours http://www.clublexus.com/forums/gs-second-...-direction.html Quote Link to comment Share on other sites More sharing options...
