My 93 ls400 started running really bad. Mechanic said that the cats were burned out. I changed them, but it runs the same. It still has no power and smells bad. No one seems to know whats wrong with it. One mechanic thinks that its the ecm, but I changed it several months ago and when it went out the check engine light and the trac light came on. The dang thing shows no codes. Any one have any ideas.
Try thre "incomplete combustion" section
diag.pdf
Thanks Ian! Very cool PDF! That one is getting printed out and put in my shop file for the car.
Ask your tech if he has an auto detective black box. It's a digital event data recorder that connects through your obd port. It will record various parameters while you're driving and usually has a red button you press if you need to, in the event of a malfunction, so they can pinpoint the event and compare data before and after. After you've driven with it installed, it's removed and connected to a pc to read the data.
Btw, I agree with ls400, good pdf Ian. Everyone should find it usefull and have it handy.
Sure seems like the ignition coils went bad. Especially the one on the side of the engine, not the one on top. Or maybe the wiring to the coils.
Hope it's something simple like this. Best of luck.
