rcmal Posted May 12, 2009 Posted May 12, 2009 I have a 2001 RX300 and there seems to be a leak from where the seat belts attache to the bottom of the car. My guess from reading leaks, it can be from a drain clog in the moon roof. If so, I only see 2 drain holes and is there drain holes for the roof rack? Does anyone kknow where they are? And do I just blow air from a compressor to clear out the drain holes? Thanks in advance
jmcohen23 Posted May 12, 2009 Posted May 12, 2009 interesting, my brother-in-law had the same issue with his Volvo. Yes, it was a drainage issue coming from the moon roof. I think they realized that the setting under the seat was not patched correctly (indicating that this was not the first time it happened). Anyhow, he took it in to the dealership, and they fixed it for about $200-300.
code58 Posted May 13, 2009 Posted May 13, 2009 I have a 2001 RX300 and there seems to be a leak from where the seat belts attache to the bottom of the car. My guess from reading leaks, it can be from a drain clog in the moon roof. If so, I only see 2 drain holes and is there drain holes for the roof rack? Does anyone kknow where they are? And do I just blow air from a compressor to clear out the drain holes?Thanks in advance The drain tubes from the sunroof NORMALLY go down each front pillar (windshield post). There would be no reason for there to be a drain from the roof rack.
