Xarnette15 Posted May 6, 2009 Posted May 6, 2009 the vibration start after i pass 50 mph Are you refering to a GS or ES? Title says GS, your info says ES. Aside from balancing tire / alighnment you may want to look at your rotors to see if they are warped. Try searching the forums. Im not sure about the ES lineup, but 2GS' are known for some vibration. Mine hits 65-75 but is butter aside from that.
sakataj Posted May 6, 2009 Posted May 6, 2009 here look over these....this should fix it or try getting aluminum hub centric rings http://www.clublexus.com/forums/gs-second-...ines-fixed.html http://www.clublexus.com/forums/gs-second-...adjustment.html steering rack bushing DIY http://www.clublexus.com/forums/suspension...ck-bushing.html
