averona Posted April 16, 2009 Posted April 16, 2009 Speedometer needle was stuck at 0 mph for a while today. Then eventually in popped back to normal. Any ideas? (1995 LS400)
mimstim Posted April 16, 2009 Posted April 16, 2009 Speedometer needle was stuck at 0 mph for a while today.Then eventually in popped back to normal. Any ideas? (1995 LS400)
mimstim Posted April 16, 2009 Posted April 16, 2009 Speedometer needle was stuck at 0 mph for a while today.Then eventually in popped back to normal. Any ideas? (1995 LS400) Had same problem,1999 LS 400.I have a loose connection in dash.Bang on top of dash to see if it pops up.Only happens very rarely.Good Luck !! ;) ;)
mimstim Posted April 16, 2009 Posted April 16, 2009 Experienced same intermittent problem with 99 LS.Loose connection in dash ?Try banging on top of dash and see if it pops up.Good luck!!
Marklouis Posted April 16, 2009 Posted April 16, 2009 Experienced same intermittent problem with 99 LS.Loose connection in dash ?Try banging on top of dash and see if it pops up.Good luck!! Same thing happens in my 95LS every month or so, had to also slap on the top right side of the dash to get it moving again. havent taken the Dash Cluster out yet to remedy the problem!
