Krsone_69 Posted April 14, 2009 Posted April 14, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250?
my95tsi Posted May 22, 2009 Posted May 22, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? I wish I knew...it's the only thing that I absolutely cannot stand about the car.
carlexes330 Posted May 23, 2009 Posted May 23, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? sorry there isnt one . It was only available upto 2008
dcfish Posted May 23, 2009 Posted May 23, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? I am researching this as I type B)
amylyn Posted May 23, 2009 Posted May 23, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? So wait.... the navigation does not continuously navigate for you like other cars? I am picking my lexus up on monday and it has nav, but might be disappointed if it does not work. and about this hack.... do you have to enter it everytime you wanna use or just once originally?
dcfish Posted May 24, 2009 Posted May 24, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? Yes, Your in luck, I have the part, There is a jdm adaptor which is plug in and play with no wire cutting. Or there is a way to cut the speed sensor wire and install a switch which is kind of tricky. Almost better to buy the adaptor. I have one in stock if you want to buy one. It works with the is250 with mark levinson system 6 disc dvd cd changer. I have the mark levinson head unit in stock also if you presently do not have the mark levinson stereo.
remat457 Posted May 26, 2009 Posted May 26, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? sorry there isnt one . It was only available upto 2008 Just to be clear the over-ride is not available in 2008 models either. :( I just emailed Lexus to complain. Don't know why they can't at least tie it into the air bar sensor so at least passengers can use it.
dcfish Posted May 26, 2009 Posted May 26, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? sorry there isnt one . It was only available upto 2008 Just to be clear the over-ride is not available in 2008 models either. :( I just emailed Lexus to complain. Don't know why they can't at least tie it into the air bar sensor so at least passengers can use it. My post above also applies to your 08, I only have 1 unit. B)
2007is350blueonyxpearl Posted May 26, 2009 Posted May 26, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? Yes, Your in luck, I have the part, There is a jdm adaptor which is plug in and play with no wire cutting. Or there is a way to cut the speed sensor wire and install a switch which is kind of tricky. Almost better to buy the adaptor. I have one in stock if you want to buy one. It works with the is250 with mark levinson system 6 disc dvd cd changer. I have the mark levinson head unit in stock also if you presently do not have the mark levinson stereo. hello, how much is the jdm adapter, and the mark levinson system. thanks
whtupplaya Posted May 27, 2009 Posted May 27, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? sorry there isnt one . It was only available upto 2008 i have a 2006 lexus is250awd do u know the hack for tht one
dcfish Posted May 27, 2009 Posted May 27, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? Yes, Your in luck, I have the part, There is a jdm adaptor which is plug in and play with no wire cutting. Or there is a way to cut the speed sensor wire and install a switch which is kind of tricky. Almost better to buy the adaptor. I have one in stock if you want to buy one. It works with the is250 with mark levinson system 6 disc dvd cd changer. I have the mark levinson head unit in stock also if you presently do not have the mark levinson stereo. hello, how much is the jdm adapter, and the mark levinson system. thanks What's your email ?
2007is350blueonyxpearl Posted May 27, 2009 Posted May 27, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? Yes, Your in luck, I have the part, There is a jdm adaptor which is plug in and play with no wire cutting. Or there is a way to cut the speed sensor wire and install a switch which is kind of tricky. Almost better to buy the adaptor. I have one in stock if you want to buy one. It works with the is250 with mark levinson system 6 disc dvd cd changer. I have the mark levinson head unit in stock also if you presently do not have the mark levinson stereo. hello, how much is the jdm adapter, and the mark levinson system. thanks What's your email ?
remat457 Posted June 2, 2009 Posted June 2, 2009 Does anyone know the hack to use the navigation while in motion for the 09 IS250? So wait.... the navigation does not continuously navigate for you like other cars? I am picking my lexus up on monday and it has nav, but might be disappointed if it does not work. and about this hack.... do you have to enter it everytime you wanna use or just once originally? Just to clarify, the NAV continuously works but the touchscreen locks you while in motion requiring you to pre-enter or use the voice command to input. The lockout also will not allow you to select a phone to sync with while in motion. I emailed Lexus to complain also. My issue is that they should tie the lockout with the air bag sensor so that it will at least will allow a passenger to use while in motion.
ame03 Posted June 5, 2009 Posted June 5, 2009 where can i get a jdm adaptor for my nav hack? i got a 2008 is250
smooth1 Posted June 8, 2009 Posted June 8, 2009 where can i get a jdm adaptor for my nav hack? i got a 2008 is250 nobody knows? I guess everyone thinks maybe you should just read the thread you posted this question in and get the answer yourself.
ame03 Posted June 9, 2009 Posted June 9, 2009 where can i get a jdm adaptor for my nav hack? i got a 2008 is250 nobody knows? I guess everyone thinks maybe you should just read the thread you posted this question in and get the answer yourself. thank you...wow what a supermoderator.
dcfish Posted June 9, 2009 Posted June 9, 2009 I am sold out and won't get anymore. You can check this out...search" Lexus tv-navi "on ebay and it will come up. $245.00 with shipping. Last I saw. Good Luck guys/Gals
bartkat Posted June 9, 2009 Posted June 9, 2009 where can i get a jdm adaptor for my nav hack? i got a 2008 is250 nobody knows? I guess everyone thinks maybe you should just read the thread you posted this question in and get the answer yourself. thank you...wow what a supermoderator. We are here to help.
SW03ES Posted June 9, 2009 Posted June 9, 2009 I love people that get all demanding looking for answers LOL. We'll return your membership fee. Oh yeah...its FREE.
dcfish Posted June 9, 2009 Posted June 9, 2009 I love people that get all demanding looking for answers LOL. We'll return your membership fee. Oh yeah...its FREE.
ame03 Posted June 10, 2009 Posted June 10, 2009 I love people that get all demanding looking for answers LOL. We'll return your membership fee. Oh yeah...its FREE. Demanding? WTF? are we reading the same thread?...lol
bartkat Posted June 11, 2009 Posted June 11, 2009 I love people that get all demanding looking for answers LOL. We'll return your membership fee. Oh yeah...its FREE. Demanding? WTF? are we reading the same thread?...lol This post came off as rather sarcastic whether intended or not. where can i get a jdm adaptor for my nav hack? i got a 2008 is250 nobody knows? I guess everyone thinks maybe you should just read the thread you posted this question in and get the answer yourself. thank you...wow what a supermoderator.
