1992 Sc400 Fuel Pump Installation Need Help Please
rnaves
rnaves, Down load the Sc workshop manual, in the link below. Type page 2031 in top left box of pdf file and scroll to end of fuel pump process and you have your answer.
http://www.zshare.net/download/5185463529a5bf95/
Can use this for a reference too, just stop before steps 3 and 4.
http://us.lexusownersclub.com/forums/index...l=rear+speakers
I have looked for you on 2 other lexus forums and cant find step by step instructions for you. But I can tell you to remove the back trunk liner, or trunk mat, then remove the back padding under your rear speakers, this simply pulls straight towards the rear of the car, and is held by metal clips. This will access your fuel tank. They said it has 8 bolts located on the top of the tank. This should get you started somewhat. Make sure to disconnect your battery first. I will keep looking for you. Sorry I couldnt be much more help!
