Texus Posted January 9, 2004 Share Posted January 9, 2004 I got a real high pitched squeal from the rear wheel(s), i'm sure it's the brakes but I thought I would throw it out in case there is something else I could check. Thanks in advance Texus Quote Link to comment Share on other sites More sharing options...
gbhrps Posted January 10, 2004 Share Posted January 10, 2004 You have four wheel disc brakes on an ES, and each wheel has one brake pad that has a small metal finger attached that points at the rotor. The idea is that when the pads wear down to the point where the pads should be replaced, the metal finger will contact the rotor making a squealing sound whenever the brakes are applied. This is the signal to get your brakes checked asap. Sounds like your problem. The only other time I've heard the same sound and it wasn't the "early warning finger", was on a car where the driver ignored the warning squeal, or the metal finger had worn off/fallen off and the brake pad material was completely gone, and the metal backing plate of the pad was scraping on the rotor. That guy's repair bill was astronomical. Quote Link to comment Share on other sites More sharing options...
zeta Posted January 10, 2004 Share Posted January 10, 2004 hrmm... uh`oh... i think i need to check my brakes then... this has been making the sound for a while, but the lexus tech that did maintenance on my car a while back checked all four pads and there was still at least 70% pad left... so i was pretty sure i'm safe... but i guess i'm gonna have to check that out some more then... heh always good to know that something's wrong with this car... kev Quote Link to comment Share on other sites More sharing options...
dropspace Posted January 10, 2004 Share Posted January 10, 2004 the last time the brakes were changed, the person changing them may not have included the shims or put any anti-squeal compound on the backs of the pads. they may be just squealing in the calipers Quote Link to comment Share on other sites More sharing options...
steviej Posted January 10, 2004 Share Posted January 10, 2004 if you are having a mechanic check your rear brakes have them check the emergency brake setup also. ES's have a drum in disc style e-brake set up. These tend to get crusty and rusty from lack of use. If it is not you rear brake pads, it may just be the e-brake mechanism needs a thorough cleaning. This was the case for a friend of mine's 96 ES. steviej Quote Link to comment Share on other sites More sharing options...
zeta Posted January 11, 2004 Share Posted January 11, 2004 hey steve, see in my case, the rear brakes squeal unless i apply my brakes... and then when i pull on the handbrake, there's a slight squeal from the tightening of the calipers i'm guessing. not sure if it just needs a small oil down or something. kev Quote Link to comment Share on other sites More sharing options...
Texus Posted January 15, 2004 Author Share Posted January 15, 2004 Thanks for the input everyone. I'm 90% sure its the brakes but check this out - it never happens when you apply the brake, only when driving around or on the freeway and it will just start. Wierd, but I'll have the brakes checked and eliminate that and go from there. Thanks again ;) Quote Link to comment Share on other sites More sharing options...
