ericvans Posted March 26, 2009 Share Posted March 26, 2009 How do you remove the rear rotor from a 2001 GS430? Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted March 27, 2009 Share Posted March 27, 2009 After the caliper and pads are out of the way and you loosen the emergency brake pads inside the rotor hat, you insert two metric bolts in the threaded holes located 180 deg. apart in the face of the rotor. As you tighten the bolts evenly from side to side, it puts pressure on the hub behind the rotor. The rotor will pop right off. If the rotor is aftermarket, it may not have the holes. In that case, use the sledge on the back side of the rotor. After you whack a rotor with a hammer, it must be replaced. It is not recommended to reuse a rotor that has been subjected to such stress. Quote Link to comment Share on other sites More sharing options...
