casper Posted March 23, 2009 Posted March 23, 2009 My Climate Control is always on and won't shut off when I press OFF button. I can change the mode and the temperature, only OFF button unresponsive. I'm wondering if I disconnect the battery would it fix the problem? Please advise what else can i do. It is 2004 GS300.
Lucky13 Posted March 23, 2009 Posted March 23, 2009 If you disconnect the battery the climate control will certainly go off.
casper Posted March 23, 2009 Author Posted March 23, 2009 If you disconnect the battery the climate control will certainly go off. Would I have to enter code for my stereo or it will automatically reset??
casper Posted April 21, 2009 Author Posted April 21, 2009 OK, I've done that (disconnected and reconnected the battery). The climate control was off when I turned the car on, but it won't turn off again. I'm lost, i have no idea what the problem is?!
sakataj Posted April 21, 2009 Posted April 21, 2009 is this non nav climate control assy? if so just replace it and see if it continues to do this....they are cheap from junkyards
