What Is A Good Injector Cleaner
billydpowell
Looking for a good engine cleaner to add to my gas......
any one with good or bad experence????
Most top tier suppliers already mix additives into their prem fuel, so you really don't need any if you're using their fuel. Next time you fill up, check the pump for stickers describing what if any additives are in the fuel. If yours doesn't have any, change to one that does.
good question, I am not experencing any negative performance, just dont want to have any and then try to overcome it.
I guess it would be as a preventive measure.
thanks for all your input.
cheers, bp
Why?
As pointed out, just use a good grade of gasoline from one of these top tier suppliers ---> http://www.toptiergas.com/
