Rotors (help)
blacklexus90
If "they" already upgraded the calipers and rotors..
..I think it's safe to assume the rotors are already upgraded??
A little more detail might be helpful in this case. ;)
well i have not bought the rotors yet that is y I am asking should I or can I upgrade to bigger rotors??
What is the need for upgrading if it's already upgraded I'm saying.
You said "they" (I'm assuming is a pronoun for the previous owner) already upgraded the calipers and rotors...
Are you wanting to upgrade even further?
Like Supra brakes? Or 2nd gen Brakes?
Sorry when I said they, I meant they upgraded they lexus model in 1993-1994 braking system.I brought they 1993- 1994 calipers dual piston but reading further in that upgrade for that year they also upgraded the rotors bigger rotors.What i am saying is will the 1993-1994 rotors fit my year 1992 as well??
yes, you can use the 93-94 rotors to complete your minor brake upgrade.
the difference, however, will be minimal. most in search of improved braking performance upgrade to the 95-00 LS400 calipers/rotors since they are HUGE and 4piston lightweight aluminum calipers. to do that swap you need 95+ caliper, pads, rotors, and lower ball joints, as well as wheels that wil fit over the larger calipers.
COOL THANKS A LOT FOR THE INFO, I AM RUNNING ON MY CAR NOW 20 WHEELS SO THAT SHOULD BE FINE
Oh that's what you're doing????? Changing to the 93-94 brake would be a waste of resources IMHO. Not very much of an upgrade.
You should go with the 95-00 brake system.
There is a Supra TT front brake upgrade for $899.00 here.
http://luxurymods.com/index.asp?PageAction...&ProdID=542
