Does anyone know of a site or can help in the description, labor and parts to replace the camshaft seals and or crankshaft seals on a 92 SC400...I would like to take on the project myself......Thanks
there should be a DIY on timing belt and waterpump. do a search and that is what you will have to do. probably the hardest thing you will have to do is take the crank bolt off. snap on sells a tool for this if you invest in it it will make your life much easier.
