piotr74 Posted January 5, 2004 Posted January 5, 2004 hey guys I have a problem with my 2001 lexus RX300 it will not start and when I connect my OBD scaner it will not connect with computer the scaner shows linnking error maybe somebody knows what this could be. Thanks
AWJ Posted January 5, 2004 Posted January 5, 2004 I take it you checked the battery already. If the battery doesn't hold charge, the alternator can be suspect. If you hear only a clicking when you try to start and know the battery is ok, perhaps you may suspect the contacts in the solenoid have worn too far - wich is not unlikely. Then you get into more developed problems if the car is still not even starting. Your scan tool may be doing that for a number of reasons: - it may not be compatible with the Lexus dlc's - the cable might be bad - the dlc in you are using may have a problem - there is some procedural error ocurring Oh - I moved your thread too, some RX guys might have some better info for ya. Good luck and welcome to the USLOC.
SKperformance Posted January 5, 2004 Posted January 5, 2004 your RX is obd 2 not obd so if it is an older system then it will not work on the newer one to connect. you also don;t leave much information to help you diagnosis the problem. It don;t start doesn't say much. gas terminals battery alternator key ???????? catch my drift need more pertinant info ? think about if you walked into the dealer , what questions would they as you ?
piotr74 Posted January 5, 2004 Author Posted January 5, 2004 ok let me put it this way my RX300 will cranks but won't start battery and spark plugs are new, engine is cranking but want start at all, looks like it want start only on 3 cylinders becouse one side of the engine is warm and the other side of the manifold is cold. When I connect to OBD2 it will not connect, my scaner works with other lexus fine it connects with no problems. the car is geting a spark and has strong fuel presure. and yes the ecu see's the master key. any help would be great. :(
SKperformance Posted January 5, 2004 Posted January 5, 2004 just wondering ,don;t you have a warrenty? it might be a coil problem? which bank is hot and cold front or back ones? the front are still coil on plug but the rear are plug wires connecting to a coil poack in front?
piotr74 Posted January 6, 2004 Author Posted January 6, 2004 all six are coil paks and no waranty car had a salvage title dealer won't honer war..
SKperformance Posted January 6, 2004 Posted January 6, 2004 when is the last tiem the car started? Is this a new engine in the car? i am pretty sure after 96 or so all 1mz-fe engines changed the coil pack configurations? also which bank is cold ,you didn;t mention?
piotr74 Posted January 6, 2004 Author Posted January 6, 2004 rear bank and the car has the same engine 21k miles on it / it started fine a week ago ..
