Steering Wheel Radio Control
Is there any way to make the up/down buttons on the steering wheel not just run through your memory set stations, but rather have the same function as the tune knob - so I can just go from 88.1 to 88.3 to 88.5 to 88.7 & so on?
This is not exactly what you want, but it will get you to a broadcasting station rather than just your presets: (from the manual)
Press ∧ or ∨ on to select a radio station.
To scan for receivable stations, press and hold the switch until you hear
a beep.
