Dvd Headrest Install
rjh959
  • 2 months later...
  • 5 months later...
Anyone ever install a DVD player headrest in a RX350? The dealer quoted up to 6 hours.
i do them all the time.... 2 hours TOPS....
What all is involved with the two DVD Player in the headrest set installation in regards to a 2007 RX350?
Is removal of the center console required? Best method for this?
Where is the controller module typically mounted/placed?
Do you typically tap into the 12VDC circuit located at the front of the lower center console?
Any additional pointers you can think of?
  • 11 months later...
To the average consumer installing a headrest dvd player monitor can be a little too extreme. You no longer have to fear cutting your factory headrests; instead, you can drop in a genuine leather or genuine fabric, perfect match replacement headrest with integrated monitor and DVD player. We offer the largest selection of perfect match replacement headrests for your Lexus automobile. Take advantage of a simple process installing an engineered solution which looks like it came from Lexus.
