Graceless Posted February 2, 2009 Share Posted February 2, 2009 I just added washer fluid and I can't latch the hood. The release handle under the dash won't return to the original position. Have I lost a spring? Any ideas would be greatly appreciated. Graceless Quote Link to comment Share on other sites More sharing options...
smooth1 Posted February 3, 2009 Share Posted February 3, 2009 It's possible. Or maybe the latch needs some lube? You also might want to check the adjusters at each corner over the headlights and make sure they aren't out to far and maybe making the hood too hard to close. Quote Link to comment Share on other sites More sharing options...
Sean John Posted February 21, 2009 Share Posted February 21, 2009 Had the same problem.... they just cleaned and lube the hatch, and everything went back to normal! Eric L. Quote Link to comment Share on other sites More sharing options...
