aberger Posted February 2, 2009 Share Posted February 2, 2009 I need to replace the front seat passenger headrest on my 2003 GX 470. I believe the color is Tan. Does anyone know if the 2006 model is the same as the 2003? Did Lexus change the color or specs in the various years for the headrests? Does anyone know the OEM number or a good source, other then a dealer, to buy the headrest? Quote Link to comment Share on other sites More sharing options...
TA in KC Posted February 3, 2009 Share Posted February 3, 2009 The colors available for the 2003 GX interior were "Ivory" and "Medium Gray". It sounds like you have the Ivory interior. The part number for the Ivory headrest is 71910-60660-A0. I don't see any reason why one from another year GX would not also fit. If you don't want to purchase a new one, I suggest you try a place like Graham's Toyota Parts. But I doubt many salvage yards will want to seperate a headrest from the seat it is currently attached to. You would probably have to purchase the whole seat, meaning that in this case it would probably be cheaper just to purchase a new OEM part from a Lexus dealership. Sewell Lexus' online parts store may be cheaper than your local dealership. Quote Link to comment Share on other sites More sharing options...
aberger Posted February 6, 2009 Author Share Posted February 6, 2009 The colors available for the 2003 GX interior were "Ivory" and "Medium Gray". It sounds like you have the Ivory interior.The part number for the Ivory headrest is 71910-60660-A0. I don't see any reason why one from another year GX would not also fit. If you don't want to purchase a new one, I suggest you try a place like Graham's Toyota Parts. But I doubt many salvage yards will want to seperate a headrest from the seat it is currently attached to. You would probably have to purchase the whole seat, meaning that in this case it would probably be cheaper just to purchase a new OEM part from a Lexus dealership. Sewell Lexus' online parts store may be cheaper than your local dealership. Thanks for the reply. I actually called Lexus and they told me a subsequent year would not fit as the part had changed. When I called a Lexus dealer for the cost of the replacement headrest is was over $600! I know its a Lexus, but its a lousy headrest. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted February 6, 2009 Share Posted February 6, 2009 There are a number of online sellers of discount Lexus parts. I've gotten some great discounts at Sewell Lexus without supplying one of their bogus discount codes: http://www.sewellpartsonline.com/ There are other sellers that might give a better discount. What's the problem with your headrest? If the leather is torn, perhaps it could be recovered by an upholstery shop. "Ivory" leather may vary a little but I'd bet you can find some that matches almost perfectly in color and texture. Quote Link to comment Share on other sites More sharing options...
denslexusgx470 Posted February 8, 2009 Share Posted February 8, 2009 The headrest is DIFFERENT starting 06. You need to order a headrest from an 03-05. Lexus enlarged the 06 and newer headrests for some reason Quote Link to comment Share on other sites More sharing options...
mann777 Posted February 9, 2009 Share Posted February 9, 2009 I think 2006 LS430 is very similar size to your model headrest, hunt around in the scrapyard, you may find one. Quote Link to comment Share on other sites More sharing options...
aberger Posted March 20, 2009 Author Share Posted March 20, 2009 The headrest is DIFFERENT starting 06. You need to order a headrest from an 03-05. Lexus enlarged the 06 and newer headrests for some reason Do you know if other Lexus or Toyota models in the 2003 to 2005 years will fit the GX 470 headrests? Quote Link to comment Share on other sites More sharing options...
