Dash Lights
leslie100
OOOO NO not the 89-94 problem again
killerFatty is referring to the "trunk hinge" wiring harness problem that seems to be incredibly common among 89-94 models...
Maybe you have a loose electrical connection somewhere or a battery that is about to die on you.
I think killer is referring to the dash cluster lights and needles that seem to go bad more often than on the 1995+ models.
I do not think the trunk hinge issue was really much related to dash cluster lights and needles not working. That was something with the actual cluster.
