Antenna Goes Up Only When The Key Is At On Position.
gonowhere
2002 RX300 with 114k. The power antenna only goes up less than a inch ecah time I stated the engine. Bought a new antenna, then realized that the antenna goes up all the way when the key is at the on position without starting the engine. As soon as I start the engine, it stops going up. Wired problem. Any suggestion will be appreciated. Thanks. Kevin
