Break Upgrade
killerFatty
I was planning on changing out the break pads and lines on my 93. I want better pedle feel and most importantly a good amount of stopping power. I am planning on using SS breaklines and EBC break pads. Has anyone used the EBC pads before and are they worth the $$. Should I use the red series or is the green series plenty good? Also do the SS lines imporve stopping power or just pedle feel? THX to all KillerFatty
SS lines will definitely help your pedal feel. The rubber lines expand when you apply pressure, while the SS ones won't.
Get lines that are DOT rated, good quality and not the cheapest ones out there. Also use a superior quality brake fluid when you replace it.
Good luck!
