Sign in to follow this
billydpowell
I Need A Keyless Entry Remote
Hi, I need a keyless entry remote for a 1995-1997 LS & program instructions.
I think HYQWDT-C or HYQ1512P
I think either will work..
anyone?
billydpowell@verizon.net
Share this post
Link to post
Hey Billy, I bought a used remote on ebay HYQWDT-C and I used the following instructions to program it. The instructions that came with my remote wouldn't work, but these did. Good luck! :cheers:
http://us.lexusownersclub.com/forums/index...ic=9825&hl=
I'm watching ebay....
Share this post
Link to post
Hi, you may not believe what I done, but I done it.
I took one of my 97 remotes, and set up the 95 to receive the 97 remote signal, by doing the following:
1. sitting in driver seat, with driver's door OPEN, press lock/unlock button ON THE DRIVERS DOOR to lock all doors, then manually unlock driver door only.
2. Insert YOUR key in ignition, DO NOT TURN, then remove key.
3. Using the same lock/unlock button ON THE DRIVERS DOOR, slowly press lock-unlock in 5 cycles
4. Shut door.
5. Open door.
6. Using the same lock/unlock button ON THE DRIVERS DOOR, again slowly press lock-unlock in 5 cycles
7. With the door open insert your key into the ignition, turn to 'on' position (DON'T START), wait 5 seconds. Turn off and remove key.
8. Locks should cycle once (Car will lock and then unlock once by herself). If they don't cycle or they cycle more than once, do steps 1-7 over.
9. Now using the remote, push lock button, hold for one second, then release the button. The locks should cycle once. If not, start over and go slower.
10. Close the door.
11. Open the door.
12. Press the lock button on the remote. The locks should do a lock-unlock cycle.
13. Close the door
14. Press the lock button on the remote, the doors should lock.
15. Press unlock button and the doors should unlock.
Now my remotes will work on either car.
I only have to have one with me and my wife can have the other, and it locks/unlocks/opens trunk.
How cool is that??
we have different keys for our cars but only one remote..
It worked for me.. bp
Share this post
Link to post
i have a set of 99 gs keys? dont have instructions though.
My 98 gs300 needed a new battery and new tire. Funds were low and it ended up sitting for a few months. In the mean time I have lost my key. I had remote start put in, so I only have 1 key now. Are you interested in selling your key - if it will work on the 98 gs 300?
Share this post
Link to post
yep, cant see why it wouldnt work. ill take pics tonite 4 ya. i also have the vallet i believe.
Share this post
Link to post
