JRohrer Posted January 21, 2009 Share Posted January 21, 2009 About a month ago, my mechanic replaced the right and left upper and lower control arms / ball joints. When he did, he found that on of the hoses from the air shock system was cracked and replaced it. After that, the "Height High" light on the dash (lower left side) flashes on intermittently. Although, it flashes more often than not. When it is flashing, I can not turn it off with the switch. However, if the light is not on, I can change the switch to high and the light comes on and stays on. What exactly is the ride height button's function? Any ideas on why the light is flashing? The mechanic thought it may be the switch (his computer would not pop any codes). Any help would be GREATLY appreciated!!! Thanks, Jon ;) Quote Link to comment Share on other sites More sharing options...
90LS400Lexus Posted January 21, 2009 Share Posted January 21, 2009 What model year is this car? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted January 21, 2009 Share Posted January 21, 2009 The "Electronically Modulated Air Suspension" system is likely discussed in the "Starting and Driving" section of your owners manual. The High position of the Height button raises the car body slightly on its suspension "For driving on rough roads which are unsurfaced or continually bumpy." Also from the owners manual: "If the "HI" indicator light blinks, there is a malfunction in the system. Have the system checked by your Lexus dealer at the first opportunity." There is a lengthy diagnosis procedure for the Air Suspension system in the repair manuals for your car. If your you or your mechanic do not have the repair manuals, the diagnosis procedure can be found at the subscription based online Lexus techinfo website Quote Link to comment Share on other sites More sharing options...
JRohrer Posted January 22, 2009 Author Share Posted January 22, 2009 What model year is this car? It's a 1995. Jon Quote Link to comment Share on other sites More sharing options...
