Sign in to follow this
normano
Climate Control
i have a 2007 460 lexus. when we turn on the car the heating system always reads 75 degrees even tho we had previosly set it at 68 ddegrees the last time we have used the car. we then lower the temp. settin to 68 degrees. how can we corect?
Share this post
Link to post
Make sure the "auto" button it pressed and make sure there is a green light near "auto" on the "inside/outside air" button.
You can also hit the "climate" button and make sure the bar above A/C is lit. The air conditioner won't turn on in the winter when it's cold, but will keep the climate control in "auto" mode.
After everything is in auto mode, you should only need to use the "Temp" buttons from now on -- winter or summer -- to keed you automatically comfortable.
Share this post
Link to post
Loading...
