camlex Posted January 8, 2009 Share Posted January 8, 2009 Hello, On my passenger side, the electronic control for the window is not working. The switch works when the window rolls down, but for some reason, it's not working when I want the window to go up. However, from the control on the drivers side, the window does go up. Any ideas why the passenger side control is not allowing the window to go up? I can't believe this car is giving me this problem with such little mileage. Thanks Quote Link to comment Share on other sites More sharing options...
dcfish Posted January 8, 2009 Share Posted January 8, 2009 Hello,On my passenger side, the electronic control for the window is not working. The switch works when the window rolls down, but for some reason, it's not working when I want the window to go up. However, from the control on the drivers side, the window does go up. Any ideas why the passenger side control is not allowing the window to go up? I can't believe this car is giving me this problem with such little mileage. Thanks Sounds like the switch is dirty ;) Try removing the switch and clean the contacts. Quote Link to comment Share on other sites More sharing options...
gbhrps Posted January 8, 2009 Share Posted January 8, 2009 Ditto. The passenger side power window switch needs a cleaning. Go to Radio Shack or an auto parts store and get a spray bomb of electrical contact cleaner (or volume control cleaner is what Radio Shack may call it). You can try spraying it right into the openings in the switch while it is in the door panel and cycle the switch several times up and down, all of this with the ignition switch turned off. Give the fluid 4 or 5 minutes to evaporate and then power up the switch and give it a try. If after 2 or 3 attempts at this it still doesn't work, you may well have to remove the switch from the door to get at its bottom and side openings and try spraying it again. If after all of this it still doesn't work, you'll have to replace the switch. Good Luck! Quote Link to comment Share on other sites More sharing options...
camlex Posted January 8, 2009 Author Share Posted January 8, 2009 Thank you . Quote Link to comment Share on other sites More sharing options...
camlex Posted January 8, 2009 Author Share Posted January 8, 2009 Not Great, The BEST cars.. I am going to continue till................. What is the life of engine? Thanks, Quote Link to comment Share on other sites More sharing options...
Lexucan Posted January 9, 2009 Share Posted January 9, 2009 Not Great, The BEST cars.. I am going to continue till................. What is the life of engine? I thought I was pushing the envelope with 270,000 clicks on the odo. Guess my baby still has some life left in 'er yet. I had a similar window problem last year. Ended up getting a new (used) switch for it. Problem gone. And I agree with you: not Great, the BEST! Quote Link to comment Share on other sites More sharing options...
dario Posted January 9, 2009 Share Posted January 9, 2009 Well I have 1986 Volkswagen JETTA Diesel that has over half a million miles everything original and it is 22 years old every car will last long as long as it is maintained. Quote Link to comment Share on other sites More sharing options...
camlex Posted January 9, 2009 Author Share Posted January 9, 2009 Thanks to DCFISH and GBHRPS, yes after cleaning the switch, it's working fine. This car don't like, that i spent money on it. Thanks, Quote Link to comment Share on other sites More sharing options...
