cscheuher Posted January 6, 2009 Share Posted January 6, 2009 Key Fob for my wifes ES-350 does not work. Are there batteries to replace? Can this be done at home? Quote Link to comment Share on other sites More sharing options...
gordonw Posted January 6, 2009 Share Posted January 6, 2009 The battery is a CR1632, and its very easy to replace. Quote Link to comment Share on other sites More sharing options...
lowrideraz Posted January 6, 2009 Share Posted January 6, 2009 Your owner's manual gives you specific instructions on how to do this this. It's funny, the recommended services manual for my F recommends the battery be changed every 12 mos or 10K miles. The recommended services manual for my wife's ES makes no such recommendation Remotes and batteries are the same for both cars. Lou Quote Link to comment Share on other sites More sharing options...
peteanello Posted January 6, 2009 Share Posted January 6, 2009 Do a YOUTUBE.COM search and a guy shows how to replace the battery. I found it a little tricky separating the fob. Using the key inside of it, is just ther right size to fit in the slot. Quote Link to comment Share on other sites More sharing options...
Billglea Posted January 6, 2009 Share Posted January 6, 2009 Your owner's manual gives you specific instructions on how to do this this. It's funny, the recommended services manual for my F recommends the battery be changed every 12 mos or 10K miles. The recommended services manual for my wife's ES makes no such recommendation Remotes and batteries are the same for both cars. Lou Dealer will charge about $15. You will not be able to find this battery in any store, but its available on the Internet for a dollar or two. Quote Link to comment Share on other sites More sharing options...
rjt65 Posted January 6, 2009 Share Posted January 6, 2009 also even if bat dead u need to hold the fob right on the start button and the car will still start.... not 1 inch away but right on it than press. batteries gor for like 2-3$ on amazon http://www.amazon.com/Energizer-Lithium-Wa...=A1GFLNAPT0JWTH Quote Link to comment Share on other sites More sharing options...
streaky387 Posted April 14, 2009 Share Posted April 14, 2009 Do a YOUTUBE.COM search and a guy shows how to replace the battery. I found it a little tricky separating the fob. Using the key inside of it, is just ther right size to fit in the slot. can you post the link for this? i couldn't find the demo for the same model key fob. THANKS Quote Link to comment Share on other sites More sharing options...
peteanello Posted April 14, 2009 Share Posted April 14, 2009 This is what I was referring to: http://www.youtube.com/watch?v=Za7pCdUde3U And you can get the batteries at Radio Shack for a couple of bucks. Quote Link to comment Share on other sites More sharing options...
