Transconductor08 Posted January 1, 2009 Share Posted January 1, 2009 I am trying to do thorough research to find better tires than the OEM Bridgestones since they are too expensive and not the best. A friend of mine has a Subaru WRX and has had excellent luck with General Exclaim UHP tires. These tires are available from Tire rack and are very inexpensive (around $100/tire). They are rated very well and I would concur since I have been a passenger in his car and like the tires. On to my point then...General makes the Exlaim to fit the front of the IS250 but they don't make one in a 255 width for the rear; they do make a 245 width however. If I am correct, the 245 is 1 centimeter slimmer than a 255. Does anyone know if the slightly smaller, 245 width tire would fit the rear wheel with no issues? If so, this looks to be an excellent alternative. Update 1/4/09: I called General direct and they DO have the rear tire in the correct size; Tire Rack was not aware but the part no of this tire is 15487500000 in case anyone is interested in giving these tires a try. Quote Link to comment Share on other sites More sharing options...
bartkat Posted January 2, 2009 Share Posted January 2, 2009 I would never downsize from the OEM tires. Quote Link to comment Share on other sites More sharing options...
sktn77a Posted January 7, 2009 Share Posted January 7, 2009 Update 1/4/09:I called General direct and they DO have the rear tire in the correct size; Tire Rack was not aware but the part no of this tire is 15487500000 in case anyone is interested in giving these tires a try. So did Tire Rack say they could get this tire? Please post your initial thoughts on the tires if you get them as I'm interested in getting the Generals, too. Quote Link to comment Share on other sites More sharing options...
