redsc4 Posted December 19, 2008 Share Posted December 19, 2008 hello every body i am a new lexus club member i have a 1995 sc400 , every time i am driving over small bumps i have knock in rear. installed rear upper (A) arm bushings and rear struts noise still there can some one help me please i would appriciate that ........ * I moved your post to the correct forum and listed it here. Smooth 1 Quote Link to comment Share on other sites More sharing options...
redsc4 Posted December 19, 2008 Author Share Posted December 19, 2008 knocking in rear over smal bumps replaced rear upper A arm bushings and rear struts still there need help please Quote Link to comment Share on other sites More sharing options...
M.Rad. Posted December 20, 2008 Share Posted December 20, 2008 Mine had a blown right rear shock that did the same. Replacement is easy and relatively inexpensive. Rides great now, no noise. Regards, M.R. Quote Link to comment Share on other sites More sharing options...
eatingupblacktop Posted December 20, 2008 Share Posted December 20, 2008 Sounds like suspension alright. Get under there and start grabbing and shaking components to check for loose parts or worn bushings. Also check your exhaust hangars. Quote Link to comment Share on other sites More sharing options...
redsc4 Posted December 21, 2008 Author Share Posted December 21, 2008 thank but i found the problem bad rear coil springs went to junk yard picked up set of springs installed them on test drove the car drives just like a new one thanks all........................... :) Quote Link to comment Share on other sites More sharing options...
