doboy42069 Posted December 13, 2008 Share Posted December 13, 2008 I have a 01 gs300 and my ac works fine but i turned on the heater and its only hot on the drivers side. Dual climate control both set to 85 but only drivers side is hot! Can anyone Help me out? One more thing everytime i start my car there is a loud buzzing sound that can be heard from inside the car. Any ideas guys? Thank you Quote Link to comment Share on other sites More sharing options...
sakataj Posted December 15, 2008 Share Posted December 15, 2008 I have a 01 gs300 and my ac works fine but i turned on the heater and its only hot on the drivers side. Dual climate control both set to 85 but only drivers side is hot! Can anyone Help me out?One more thing everytime i start my car there is a loud buzzing sound that can be heard from inside the car. Any ideas guys? Thank you welcome to the forum,try to use the search tab for yourself this way we dont end up with 20 posts bout the SAME thing which i promise we already do, i have seen like 4 on the servo motors n the last month ! http://us.lexusownersclub.com/forums/index...=Search&f=1 what you have is a bad servo motor...its the temp servo you need...... the part #'s the mode 87106-30371 and the cooling 87106-30340 have to double check these at the house but they should be right. i suggest changing the mode servo while your in there so you dont have to open her back up! NEWAYS i will post some links bout this but in the future as i stated try searching some old posts first! http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://us.lexusownersclub.com/forums/index...;hl=servo+motor http://www.clublexus.com/forums/gs-second-...nger-sides.html http://www.clublexus.com/forums/gs-second-...tml#post3823177 in one of these links you should be able to better understand. i do have a DIY started with pics but man im so busy i havent gotten much done on it Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted December 17, 2008 Share Posted December 17, 2008 I guess i should read up on this too... its starting to seem like an all too common issue... Quote Link to comment Share on other sites More sharing options...
sakataj Posted December 17, 2008 Share Posted December 17, 2008 I guess i should read up on this too... its starting to seem like an all too common issue... its really a simple fix.....just annoying to have to do. im doing mine for a 2nd time now as i bought some used ones from a totalled car and they were bad also.......so im not doing this AGAIN! yeah blah <_< Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted December 18, 2008 Share Posted December 18, 2008 take pictures and do a write up and completely off topic... why is there even a smiley like this.. :snoooorrrtttt: Quote Link to comment Share on other sites More sharing options...
sakataj Posted December 18, 2008 Share Posted December 18, 2008 take pictures and do a write up and completely off topic... why is there even a smiley like this.. :snoooorrrtttt: i've actually started a DIY on the servo motors but i've been so busy and so f-king lazy when i get off that i havent done much to it! i have all the pics i need just gotta put them in order and type it up! oh that smiley is for days you just feel like your rick james....... Quote Link to comment Share on other sites More sharing options...
