johmah Posted December 12, 2008 Share Posted December 12, 2008 Hi all, I have the common 93 LS400 problem of the speedometer (and tachometer) taking half a hour to work unless the car has been left in the sun for hours. It seems there are three inexpensive fixes proposed on the forum that I'm aware of: (1) Send it to Mr Whizard (he has good reports but I live in Australia so it may take too long) (2) Insert a pin in the back of the dial so the speedo can't return to zero (3) Remove lube on the limit stop-arm (detailed advice is posted on the forum, but I haven't seen confirmations that it works). Is there a definitive answer on whether (2) and (3) work? Any advice or links is appreciated. Thanx, johmah Quote Link to comment Share on other sites More sharing options...
93ls400walt Posted December 14, 2008 Share Posted December 14, 2008 I've not hears of #'s 2&3. I bought a used cluster that the prior owner had rebuilt. That was 2 years ago. Mine always works but sometimes the tach and more often the speedo will take a while to pop up. The speedo I usually have to get above 50 mph for it to work. So I am not sure the money is worth it as this may not be a long term fix. Also my gas guage had stopped working ( another issue in cold weather ) but my friend that sold me his cluster had addressed this. Quote Link to comment Share on other sites More sharing options...
