dmaddox Posted December 30, 2003 Share Posted December 30, 2003 Hello, doors have all been fine, as expected. Upon getting ready to go to work this morning, I unlocked car in the normal fashion, and it was still locked! So, I used the key to manually unlock the driver door, still acted as though it was locked. Now, I think the cable is either broken or loose on the inside of that handle. Becuase the lock works ok, you can open from the inside and all other doors can open. However, I cannot open the driver door from the outside. As you can imagine this BITES! Have any of you seen/heard of this issue, if so what is an easy fix? I'd hate to have to dig into the door panel and so on. 1994 ES300 Thanks, Dallas Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 31, 2003 Share Posted December 31, 2003 yes someone posted about this last month , i guess you missed the post. it involves replacing a pl;astic clip to attach to the door handle. Quote Link to comment Share on other sites More sharing options...
Roman Posted January 2, 2004 Share Posted January 2, 2004 Try to find my post where I tried to describe the fix for this problem. The part I used came from NAPA #735-2785 and it is still working in both front doors I had to fix. The important part is to try put a cable zip tie to hold the rod in the clip. Not easy to acomplis, but worth the time and strugle, othervise the rod may slip out. Quote Link to comment Share on other sites More sharing options...
