Sign in to follow this
inautix
Tail Lights
When the right side tail(right most) light is not working, replace blun sign comes on. This is not consistant. Sign comes and goes..when sign is off there is no problem and everthing is working. According to sign I am suppose to replace to bulb. But if buld is bad then why is works some times? Any one have seen this? any help will be apperciated. Thanks.
Share this post
Link to post
since this is related to every lexus model as it is pretty common try a search to see the fixes otehrs have done.
Share this post
Link to post
Here is why it works sometimes and not others. The filiment in the bulb breaks loose at one end. It wiggles around and when it makes contact, it works. When the contact is broken again, it doesn't. You have a bad bulb, happens all the time. Replace it and everything will be fine. If you need instructions on how to replace the bulb, email me. dwmahony@cox.net
VB denny
Share this post
Link to post
Loading...
