ARIFSHA Posted December 2, 2008 Share Posted December 2, 2008 I need help to change the oil filter on a 08 ls460, draining the oil seems easy enough but I cannot find the filter Thanks Quote Link to comment Share on other sites More sharing options...
jlawr Posted December 3, 2008 Share Posted December 3, 2008 I need help to change the oil filter on a 08 ls460, draining the oil seems easy enough but I cannot find the filterThanks Here you go: http://www.clublexus.com/forums/showthread...s460+oil+change You may need this to remove the filter: http://www.toolsource.com/toyota-lexus-fil...m-p-100298.html Other part numbers: http://www.irontoad.com/Merchant2/merchant..._Code=2008ls460 Make sure you deflect the stream of oil draining from the pan AWAY from the protective shield, otherwise oil will flow into the "cover" and get all over the bottom of the car. Good luck! Quote Link to comment Share on other sites More sharing options...
cardona6569 Posted December 12, 2008 Share Posted December 12, 2008 Hello: The oil filter is in the likes of an Aircraft engine style. If they would use metal screen wafers, instead of paper, all you would have to do is clean them with gas and presto no waste. But mercantilism needs to be alive and well. C Quote Link to comment Share on other sites More sharing options...
