Clean Valves And Lifters?
I just bought a 91 LS 400 with 213,000 mi. I just replaced the Starter, & PCV Valve. The engine makes a tapping noise when under acceleration. When I replaced the PCV Valve, I noticed that it seemed pretty sluggy in there. Would it help to remove the valve covers and clean the valves and lifters? If so what should I use? I know that in 97 the dealership ran some GM Top Engine Cleaner through it to remove a tapping sound. I wonder if I should try that again? Has anyone used this stuff on thiers? The three causes of this seem to be:
1. Sticky valves
2. Valve adjustment
3. Exhaust leak
4. Timing advanced
Do you have to reset the timing when you replace the timing belts?
I have a lot to do to this thing. Any input is appreciated.
Thanks,
CL
