trevordbs Posted November 12, 2008 Posted November 12, 2008 Any guides? Im sure its simple, just im used to working on older chevys and not comfortable with the LExus yet
IS400 Posted November 12, 2008 Posted November 12, 2008 I did not have any problems, just the usual fiddling with shrouds to get space to take things off and such. Remember to check for electrical and transmission cooler lines before you try getting it out. The fan bolts were a bit of a problem for me but it was straightforward to do. I did not use the radiator drain petcock since mine would not budge no matter the method or chemical I tried. I just took off the lower hose and thought it would be better to make a mess on the garage floor than to twist that little valve off the radiator trying to get it to open. Good luck!
