When my motor is cold and i start it, i get a nice even whistle from the engine area, as the engine warms up to normal operating temps it stops. I am fearing an exhaust leak seemingly between where the primary cats meet my exhaust system. Hopefully just needs an exhaust gasket? Any opinions, hadnt had a chance to put it on a lift while running to inspect.
Had the "whistling" happen to me as well, it turned out to be the harmonic balancer. The rubber around the main crank deteriorated and during startup would whistle until the rubber surround heated up. I would check to see if the main crank is moving once the car is on just to be safe.
