Remote Starter Installation
Marty Witt
Has anyone installed a remote starter/alarm on their SC400? If so, how difficult? Do you have the wiring diagram? How difficult was it to wire. Is the bottom of the dash on the drivers side easy to remove? etc. I just did a remote start/alarm on a 2002 Honda Civic and it required the a key transponder bypass module, I assume the Lexus would be the same. Any help you could provide would be appreciated
yeah, i need help too. i got the bulldog security reomte starter for x-mas and tried to install it the other day. i couldnt figure out how to remove some of the dash pannals in order to expose the wires from the key hole. could anyone that has had this done or knows how to do it for that matter share some info.
hmmm...I got the bulldog remote start as well, and when I took it to a audio/electronic shop they told me they definately would never reccomend that remote start. They claimed they have seen many problems with them and have stated them to be very unsafe. They also said it would cost around $100 for installation.
I found this link from Bulldogsecurity.com It is the wire colors for the 99-00 SC400. I wonder if this is the same for 95?? I don't know how to make it a link. so you'll have to cut and paste. I will read my Lexus repair manual over the next few days and see what I can dig up on panel removal.
http://bulldogsecurity.com/New%20Wires/New...sc400-99-00.htm
  • 11 months later...
I got the Bulldog for Christmas too. The guys at the local electronic shop told me the same thing. No good, too many problems and they wouldn't stand behind it if there were problems. They recommended the Viper system. Gonna have it installed on Saturday and I can't wait!
My husband is gonna try to put the bulldog on his '02 Dodge Ram. Since he's paying for the Viper and install, I let him have it. B)
I OWN A CAR STEREO/ACCESSORY STORE IN RICHMOND VIRGINIA AND I'LL BE GLAD TO HELP YOU GUYS WITH DIAGRAMS AND STEP BY STEP INSTRUCTIONS ON REMOTE STARTER INSTALLATION. I HAVE DISASSEMBLED SO MANY LEXUS' I KNOW THEM IN MY SLEEP. FEEL FREE TO CONTACT ME AT 804 358 9576 OR EMAIL ME AT SAMOHT023@AOL.COM WWW.TINTASSASSIN.COM
  • 3 years later...
i was looking for the wiring diagram also..nothing yet. :(
1992-93 Lexus SC400 Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White Ignition Switch Harness
Starter Black/White Ignition Switch Harness
Ignition Black/Yellow Ignition Switch Harness
Ignition 2 Black/Orange Ignition Switch Harness
Accessory Pink/Blue Ignition Switch Harness
Tach Black Igniter, Passenger's Fender
Brake Switch Green/White Brake Switch
Trunk Release Black/Silver Driver's Running Board
Trunk Pin Red/White (-) Driver's Running Board
Parking Lights Dark Green Driver's Kick Panel White Connector
Head Lamp Red/Green Steering Column
Hood Pin n/a
Factory Disarm Green (-) Driver's Kick Panel
Door Trigger Red/White (-) Below Fuse Panel White Connector
Door Lock Red/Black (-) Driver's Kick Panel Blue Connector
Door Unlock Green/Blue (-)
Horn Wire Green/Red Steering Column
Windows Up LF=Red, RF=Red/Blue
Windows Down LF=Green/Yellow, RF=Green/White
