jcrome04 Posted October 25, 2008 Posted October 25, 2008 I just pulled out a flashlight the other day to look at the bottom of my PS reservoir. And the beginning of one of the two hoses around the clamp looks wet like it's got some fluid on it. I haven't lost any fluid at all on the dipstick, ever. So it can't be leaking much at all.... if it is leaking I guess my question is.... is this something I should be concerned about? Are there any steps I could take to make sure nothing happens? I know I still need to do the solenoid cleaning.... (97, currently at +153k)
landar Posted October 25, 2008 Posted October 25, 2008 Clean it up as best you can and continue to monitor it for leakage.
eatingupblacktop Posted October 25, 2008 Posted October 25, 2008 JC, besides the solenoid on the rack you should check/clean/replace the acv on the pump and the reservoir screen filter. Also might want to check your rack, especially the end caps for any leakage. Here's a pic of the screen for 93-94. Don't think they've changed all that much for your series:
jcrome04 Posted October 26, 2008 Author Posted October 26, 2008 Maybe kind of a PITA to remove the reservoir???
eatingupblacktop Posted October 26, 2008 Posted October 26, 2008 Not as much as the starter. :P There's only 3 bolts and the hoses. Here's the link: http://www.lexls.com/tutorials/steering/pspumpremoval.html
dscabicky Posted November 11, 2008 Posted November 11, 2008 Oh jeeeeeez :) hahaha What's the best way to change the fluid? Can you ise a fluid extractor?
smooth1 Posted November 11, 2008 Posted November 11, 2008 just pulled out a flashlight the other day to look at the bottom of my PS reservoir. And the beginning of one of the two hoses around the clamp looks wet like it's got some fluid on it. Can you take a pic and post it?
eatingupblacktop Posted November 11, 2008 Posted November 11, 2008 Oh jeeeeeez :) hahaha What's the best way to change the fluid? Can you ise a fluid extractor? Here's the way to do it: http://www.lexls.com/tutorials/steering/psflush.html
oldskewel Posted November 20, 2008 Posted November 20, 2008 ... There's only 3 bolts and the hoses. ... Sounds easy, but all it takes is for one of those hoses (or bolts) to be a PITA to make the whole job a PITA. On my 1991 LS400 (~160k), I needed to remove the PS return line at the reservoir, for some reason that I now forget (flushing PS?). The hose had basically cooked itself on there. Very brittle, yet still strong, and seemed like it was glued on. I ended up having to destroy the hose to remove it. But yours might be easy to R+R. You never know. Good luck. Ed
jcrome04 Posted November 20, 2008 Author Posted November 20, 2008 How can a hose be VERY brittle, but still VERY strong???????? :huh:
oldskewel Posted November 20, 2008 Posted November 20, 2008 How can a hose be VERY brittle, but still VERY strong???????? :huh: Well it was. When trying to use pliers to work it free, it would crack on the surface. Yet enough of it would hold together, and the sub-surface parts were almost like they were glued on to the reservoir pipe. I quickly conceded that it would be destroyed in the removal process, and it still was very difficult to remove. Hope yours is not like it.
