ktmsooner Posted October 12, 2008 Share Posted October 12, 2008 I was checking today on some new front brakes for my 04 ls 430. I found the pads at the Lexus dealer for 85.00. The kicker is I was told that I needed to replace the bolts that hold the brake calipers on too. These bolts are 8.50 each. I have replaced many front brakes on cars and have never heard that you should replace these bolts. There are 4 of these bolts total, not that much, but is it necessary? Thanks for any input Quote Link to comment Share on other sites More sharing options...
Step Hen Posted October 12, 2008 Share Posted October 12, 2008 I've only heard of replacing bolts as one-time use only when it requires a high torque application. Quote Link to comment Share on other sites More sharing options...
SRK Posted October 12, 2008 Share Posted October 12, 2008 It is not necessary. Re-use the bolts and ignore advice like that.They are not torque-to-yield bolts. The factory uses a thread locking compound similar to Loctite blue. I don't even do that. However, if you are unfamiliar with tightening bolts by feel, use a torque wrench and install them to the factory specs. Quote Link to comment Share on other sites More sharing options...
