shadysprings Posted September 30, 2008 Share Posted September 30, 2008 As you can see from the picture, one of the studs snapped off and I am trying to replace it. Not to mention the rotor needs to be surfaced. After taking the caliper off the rear, I can't pull the rotor off. Can someone tell me if I need to remove the nut "A" off in order to slide the rotor off? And anyone know the size of bolt "B" I assume used to help unstick a stuck rotor to the hub? Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted September 30, 2008 Share Posted September 30, 2008 I don't remember how to take mine off but I do remember needing to encourage it with a rubber mallet... it kinda rusted on there... the rotors were 6 years old... Quote Link to comment Share on other sites More sharing options...
shadysprings Posted October 4, 2008 Author Share Posted October 4, 2008 What happened? There were about 10 posts in this thread including a few pictures of how I removed the rear rotor and changed a stud on hub. Am I crazy or did a bunch of posts get deleted? Quote Link to comment Share on other sites More sharing options...
bucwhokey Posted October 13, 2008 Share Posted October 13, 2008 no dont remove the A nut just hit the brake disc with a rubber mallet. Its a snug fit. Hole B is a screw with a 10mm thread i think but not really sure Quote Link to comment Share on other sites More sharing options...
Mike Eder Posted November 11, 2008 Share Posted November 11, 2008 the bolt hole is 10x1.25 and nut A is what holds the axle in the hub, just hit the rotor with a rubber mallet and replace it, dont resurface. Quote Link to comment Share on other sites More sharing options...
