Rx300 Headlights
Fsirko
  • 3 years later...
Check your relay. It's located on the radiator grill. If it's working you will hear a clicking sound.
www.jpimportz.org
Do you guys know of a place to get the relays other than the dealer? Also, to make sure, are the relays that control the high beams located in the pod that is actually attached at the radiator? Has a black, and 2 burgundy relays plus 1 fuse?
Thanks! Jeff
  • 4 months later...
www.jpimportz.org
Thanks! Jeff
I'm having the same problem on my 99 RX-300. Did the relay fix the problem?
