TexasLexus94 Posted September 25, 2008 Share Posted September 25, 2008 My A/C light here in Vegas started blinking, so I bought a gauge and some R134. Found the large A/C port, started the engine, put the A/C blower on high. Waited a while, and then connected the snap on connector, with a can of refrigerant and the gauge. The first can had some leak sealer in it. Took a while, but the can turned cold, and the gauge went from 0 psi to about 5. So then I screwed the second can into the gauge, and all hell broke loose. The coolant was spewing out of the can connection and would not go into the line. No matter how carefully I squeezed the gauge. Any ideas what I am doing wrong? Thanks for your help. Quote Link to comment Share on other sites More sharing options...
TA in KC Posted September 26, 2008 Share Posted September 26, 2008 My guess is the dispenser is the problem. I have had several cheap crap dispensers break and cause similar problems to the one you are describing. Quote Link to comment Share on other sites More sharing options...
