Telescoping Wheel Problems
Cwallbball10
I attempted to fix my telescoping wheel today, and everything was fine until I couldn't get this small nut/bolt? off...It's the bolt circled in the picture.
I read somewhere where someone replaced the nut and washer, due to a grinding noise. Try this link, and I hope it helps you out some...... http://www.clublexus.com/forums/showthread...hlight=Tutorial
I've read that same thread a MILLION times, and only one or two people are having problems like me. They haven't been answered/replied yet, so I guess I will wait...
i got mine off by getting a right sized screw driver and put it in the teeth and against the wall. my gear is bad also. only has like half the teeth so i had to manually adjust it to the proper level and switch off the button.
